Good afternoon!
Finally got around to building a new Zabbix 3.0.5 server to replace my Zabbix 1.8.13 server. I am trying to rebuild the triggers and running into a bit of a problem.
In the v1.8.13 with function "Last Value < N" I can put a "0" in the "Last of (T) Seconds" field to create the trigger:
"{QA - FIN: oracle.tns.last(0)}<1" (Added space is mine)
However, in Zabbix v3.0.5, the "Time" drop-down grays-out the "Last of (T)" field. If I "Add" it as is, and then test it using "0" for the value I get a success however I see no way to include 0 for "Time" as a static value. What I end up with is:
"A {QA - FIN: oracle.tns.last()}<1" (Added space is mine)
Trying to find out what I'm missing and doing wrong.
Thank you!
Thank you!
