Zabbix-agent2 for fedora 38
  • BalaC
    • Sep 2021
    • 22
    Hi All,
    Currently I'm running zabbix-agent on fedora os.(zabbix 6.0). I want to upgrade zabbix agent to zabbix-agent2.
    I'm not finding in the https://repo.zabbix.com/zabbix/6.0/. So how to install agent2 in fedora. If any steps really appreciate it
    Thanks!
    How did you install classic agent? Fedora is related to RH, IIRC... so use RH repo maybe? RH9 ? I don't know what's the same level RH version as F38... web says rh9 comes from F34...
    If you already have classic agent installed, that probably means, you have also a repo configured, so just try to install agent2 ? They should come from same place...
    • BalaC
      • Sep 2021
      • 22
      Thanks for the reply. I see the it came from Fedora repo, but I'm not able to see zabbix-agent2 in this repo.
      # rpm -qi zabbix-agent-6.0.27-1.fc39.x86_64
      Epoch : 1
      Version : 6.0.27
      Release : 1.fc39
      Architecture: x86_64
      Install Date: Tue Mar 19 22:04:10 2024
      Group : Unspecified
      License : GPLv2
      Signature : RSA/SHA256, Wed Feb 28 16:11:42 2024, Key ID 75cf5ac418b8e74c
      Source RPM : zabbix-6.0.27-1.fc39.src.rpm
      Build Date : Wed Feb 28 15:42:29 2024
      Build Host : buildvm-x86-27.iad2.fedoraproject.org
      Packager : Fedora Project
      Vendor : Fedora Project
      URL : https://www.zabbix.com
      Bug URL : https://bugz.fedoraproject.org/zabbix
      Summary : Zabbix agent
      Description :
      Zabbix agent, to be installed on monitored systems
