MSSQL using Zabbix Agent v6.4.13
  • MatteGary
    • Mar 2024
    I'm trying to setup the new MSSQL integration using the latest key embedded in the Zabbix Agent released with 6.4.13.
    Some reference
    Source of README.md - MSSQL - ZABBIX GIT
    1 Zabbix agent 2​
    Can you point me to the right direction?
    If I setup an item with key "mssql.version" I get the error "Unknown metric mssql.version".
    In the Zabbix Agent 2 Log i cannot see any line about MSSQL (while I see lines regarding other plugins).
    I think I should create a mssql.conf with some config key, but I canont file the correct value for the first key to configure "Plugins.MSSQL.System.Path".
    Someone knows how to make it work?
    Matte
  • icetea58
    • Apr 2023
    This is from de 'Zabbix Agent 2' 6.4.13 log.
Name:	Screenshot at Mar 29 14-48-33.png
    • MatteGary
      • Mar 2024
      So they forgot something, or are we missing something?
      Because from the instructions seems pretty straight forward, but actually it isn't.
        There was just the same topic.. you need the actual plugin also... not so straightforward to get https://cdn.zabbix.com/zabbix/binari...dows-amd64.msi
        • icetea58
          • Apr 2023
          Yup, and then it's working perfectly.
          • kamal.patel
            • Mar 2024
            • 10
            Yes, I have downloaded and install plugins which is working fine now.
            • Laurent S
              • Apr 2024
              Hello all,
              I try install msi plugins, is working perfect but since zabbix_agent2 6.4.13 is not another simple method ?
              I have 2 process starting on windows agent2 and agent2 plugins if the server restart 2 process restart in same time ?
              and 2 questions on zabbix monitoring I have access on dashboard main i have a more information but in database tab, I have not information is blank information
              I testing on sqlcmd i have more information with user zabbix on my db sql
              Have you a respond ?
              Many thanks for your help
              • Coldbold
                • May 2024
                hi,
                I have downloaded the plugin for sql server agent2.
                what will be the path foris this the location of the downloaded plugin?
