top N list for item prototype
  • znerol_1
    • Jul 2023
    Hi everybody,
    I'm having fun with Zabbix, thanks for this excellent sotware!
    I managed to have hdd stats discovered via a template with various item prototypes. I want to display a widget with the top n items for each prototype. For example the top 10 disks with highest busy percentage, ideally across a host group, but even per host would be nice.
    the top host widgets only lets me choose a very specific item per host i e a specific disk. How can I display a top ten of something like
    custom.disk.busy.disk[{#DISKNAME}]
    Cheers,
    Loz
  • Answer selected by znerol_1 at 11-04-2024, 14:06.
    salavie
    • Oct 2020
    • 29
    Suggest using Grafana + Zabbix plugins
    Using the same item name, even from different vendors
    • znerol_1
      znerol_1 commented
      yes, this works great, thank you!
    • 4993
    I think there might be somekind of dev proposal up for the feature, but as long as I remember you can not do this right now...
    • znerol_1
      • Jul 2023
      alrighty, thanks!
      I'll keep a look out for it in future versions especially in combination with a heatmap type of widget, that would be awesome!
      Peace,
      Loz
      • salavie
        • Oct 2020
        • 29
        • znerol_1
          znerol_1 commented
      • znerol_1
        • Jul 2023
        Yes, very nice! I have managed a nice map with grafana pulling from zabbix!
Name:	Screenshot 2024-03-30 at 00.36.45.png
