"Docker by Zabbix agent 2" problem with "Container {#NAME}: CPU percent usage"
  • SkyDreamer
    • Mar 2024
    Hi there!
    Initial information:
    • Zabbix: 6.4.13
    • Docker by Zabbix agent 2: 6.4-0
    • Docker: 24.0.5, build 24.0.5-0ubuntu1~22.04.1
    I'm using the "Docker by Zabbix agent 2" template.
    Statistics from containers are received without problems, except for “Container {#NAME}: CPU percent usage”.
    I see an error:
    Preprocessing failed for: {"cpu_stats":{"cpu_usage":{"total_usage":155439 400 0,"percpu_usage":null,"usage_in_kernelmode":162. ..
    1. Failed: cannot extract value from json by path "$.cpu_stats.cpu_usage.percent_usage": no data matches the specified path
    The problem is that Zabbix cannot get the value of $.cpu_stats.cpu_usage.percent_usage.
    But inside cpu_stats > cpu_usage there are only total_usage, usage_in_kernelmode and usage_in_usermode.
    percent_usage - missing​
    Docker data:
       "cpu_stats":{
          "cpu_usage":{
             "total_usage":736150758000,
             "usage_in_kernelmode":40129937000,
             "usage_in_usermode":696020821000
          "system_cpu_usage":1327539850000000,
          "online_cpus":8,
          "throttling_data":{
             "periods":0,
             "throttled_periods":0,
             "throttled_time":0
    How can I fix this?
