Replacement for Host Macros in LLD Prototype Names
  • mrgadgetnz
    • Jul 2011
    • 11
    We have recently upgraded from 5.X to 6.0, and have been bitten by the removal of the previously deprecated User Macros in LLD item/trigger names.
    We create user macros with context for each disk so the teams receiving the alerts can receive meaningful data (ie "F:\ [Profile Data]", rather than just "F:"). To achieve this, there is a host macro {$DISK_NAME:"C:\ "}, set to "[Profile Data]". This host macro is then used in the item/trigger names by using {$DISK_NAME:"{#FSNAME} "} - which is obviously not longer expanded in 6+ of Zabbix. We use the same concept to override the trigger values - this still works, it's just the use of them in the name that's been ripped out.
    I have found that where the Zabbix Agent is used, we can use {#FSLABEL}, which brings through the drive name in Windows (not ideal, but we can make it work). Unfortunately the VMware disk LLD doesn't have any other keys provided other than {#FSNAME}.
    Has anyone else run into these challenges and found a way around them?
