I want to use a wallet for Zabbix database auth to prevent storing credentials in Zabbix. Is this possible?
Using the wallet to authenticate on command line is working fine. But not with Zabbix.
My config:
My config:
mkstore -wrl /etc/zabbix/oracle_wallet -createCredential MYDB zabbix password cat /etc/zabbix/oracle_tns/sqlnet.ora DIAG_ADR_ENABLED = OFF SQLNET.WALLET_OVERRIDE = TRUE WALLET_LOCATION = (SOURCE= (METHOD = FILE) (METHOD_DATA = (DIRECTORY=/etc/zabbix/oracle_wallet)) ) cat /etc/sysconfig/zabbix-agent2 ORACLE_HOME=/opt/oracle/product/19.3.0/dbhome_1 LD_LIBRARY_PATH=/opt/oracle/product/19.3.0/dbhome_1/lib:/opt/oracle/product/19.3.0/client_32/instantclient/light/:$LD_LIBRARY_PATH TNS_ADMIN=/etc/zabbix/oracle_tns DB_LOGIN_ID=zabbix zabbix_agent2 -t oracle.sys.params["tcp://localhost:1521","","","MYDB"] oracle.sys.params[tcp://localhost:1521,,,MYDB][m|ZBX_NOTSUPPORTED] [Connection failed: ORA-01017: invalid username/password; logon denied.] sqlplus /@MYDB SQL*Plus: Release 19.0.0.0.0 - Production on (...) -> successful
