install timescale on postgresql
  • mcncyo
    • Apr 2024
    I am trying to get timescale working on postgresql. I installed both of them. but When I tried to run
    echo "CREATE EXTENSION IF NOT EXISTS timescaledb CASCADE;" | sudo -u postgres psql zabbix
    i get this error
    extension "timescaledb" has no installation script nor update path for version "2.14.2"
    can anyone tell me what i am doing wrong?
    this is how i installed postgresql and timescaledb on a clean debain computer
    Nala install gnupg2 wget
    sudo sh -c 'echo "deb https://apt.postgresql.org/pub/repos/apt $(lsb_release -cs)-pgdg main" > /etc/apt/sources.list.d/pgdg.list'
    wget --quiet -O - https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key
    sudo nala update
    sudo nala install postgresql-14
    systemctl enable postgresql –now
    sudo su – postgres
    psql
    \q
    \exit
    cd /etc/postgresql/14/main
    pico postgresql.conf
    max connection to 150
    systemctl restart postgresql
    sudo -u postgres createuser –pwprompt zabbix
    type in a password for zabbix user on postsql
    sudo -u postgres createdb -O zabbix zabbix
    wget https://repo.zabbix.com/zabbix/6.4/d...bian12_all.deb
    dpkg -i zabbix-release_6.4-1+debian12_all.deb
    nala install zabbix-sql-scripts
    adduser zabbix
    usermod -aG sudo zabbix
    change to
    listen_addresses = '*'
    pico pg_hba.conf
    change
    host all all 127.0.0.1/32
    host all all 0.0.0.0/0
    install timescale db as follows
    echo "deb https://packagecloud.io/timescale/timescaledb/debian/ $(lsb_release -c -s) main" | sudo tee /etc/apt/sources.list.d/timescaledb.list
    wget --quiet -O - https://packagecloud.io/timescale/timescaledb/gpgkey | sudo gpg --dearmor -o /etc/apt/trusted.gpg.d/timescaledb.gpg
    nala update
    sudo nala install timescaledb-2-2.13.1-postgresql-14=2.13.1~debian12
    timescaledb-tune
    change
    max_connections = 150
    Somekind of version mismatch... you install version 2.13.1 (sudo nala install timescaledb-2-2.13.1-postgresql-14=2.13.1~debian12) but during extension adding it complains about 2.14.2..? Why do you even install older version if 2.14.2 is available?
