Zabbix Security Configuration
  • ankur328
    • Nov 2016
    Hi Members,
    I have few questions related to Zabbix Configuration:
    1. I have one main Zabbix Server and 3 Agents. The problem is that they are not on the same gateway. Hence which port I should open up ? Is it 10050? I have used default settings in installation.
    2. If I open the Zabbix Server frontend to Public how should I secure the same? I mean since mysql is used it might be prone to SQL injection attacks.?
    I am using Zabbix Version 3.0
    Ankur
  • Colttt
    • Mar 2009
    • 878
    1) yes it is 10050
    2) you can use .htaccess but i think the frontend is secure
    Debian-User
    Sorry for my bad english
