log monitoring settings when failure and recovery logs output within update interval
  • trinet
    • Sep 2021
    CentOS 7 x86_64
    Zabbix 4.0.24
    MariaDB 5.5.60
    I would like to monitor that if the log that contains "test: Status is" in /var/log/messages.
    when log contains "offline", it is a failure, and if it contains "online", it indicates recovery.
    test: Status is offline ← Failure
    test: Status is online ← Recovery
    If the following monitoring settings are used (eg. item update interval is 30 seconds), when the "offline" and "online" logs are output within 30 seconds,
    both "offline" and "online" triggers will be notified.
    -- Item
    Type: Zabbix agent (active)
    Key: logrt[/var/log/messages,"test: Status is",,,skip]
    Update interval: 30s
    -- Trigger
    Expression: Item:logrt[/var/log/messages,"test: Status is",,,skip].regexp("offline")}=1
    Recovery expression: Item:logrt[/var/log/messages ,"test: Status is",,,skip].regexp("online")}=1
    Do you have any suggestions for how to set up monitoring other than shortening the update interval?
    Any help would be appreciated
