Error: ZBX_TCP_READ() failed: [104] Connection reset by peer
  • Shital Bansode
    • Apr 2024
    Hi everyone,
    I've encountered an issue while trying to monitor a website certificate using Zabbix Agent 2 installed on a Zabbix Proxy. Here's a brief overview of the setup:
    • Installed Zabbix Agent 2 on the Zabbix Proxy box.
    • Created a certificate monitoring host on the Zabbix UI.
    • Attached the website certificate using the Zabbix Agent 2 template.
    • Configured the interface with the Zabbix Proxy IP.
    • Added macros for the website hostname.
    • Specified the proxy IP in "monitored by proxy."
    Despite ensuring that the Zabbix Agent 2 is up and running, I'm consistently receiving the following error on the UI:
    "Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer"
    I'd appreciate any suggestions or insights into resolving this issue. Thanks in advance for your help!
