Unavailable by ICMP Ping.
  • RowandeRoo
    • Mar 2024
    • 9
    I've set up my zabbix server after a long troubleshooting session and came across an annoying problem in Zabbix.
    For some reason, every single host i own shows unavailable by ICMP ping, but can i see that other templates on the same host are receiving data.
    The availibility is also green for some reason, while it clearly says it's unavailable by ICMP Ping.
    Does anyone know how to fix it?
    I can ping the hosts from the zabbix server and is data collecting for some reason? I'm new to zabbix so i dont really understand why this is happening. If anyone could help me out here, that would be appreciated.
    Thanks.
  • Answer selected by RowandeRoo at 05-04-2024, 14:04.
    RowandeRoo
    • Mar 2024
    • 9
    I've managed to fix it by changing the routing of my zabbix surrounding. Thanks for the reply Cyber!
      Availability is not set by ping, but by agent availability (in your case, snmp agent availability). if you try pinging from command line, are you using same fping as Zabbix does or regular ping? Are there any errors in server logs?
      • RowandeRoo
        • Mar 2024
        • 9
