zabbix vmware vm.snapshoot.get
  • BlockSto
    • Apr 2024
    • 12
    I'm trying to find how can i monitor vmware snapshoot,
    i have try to add an prototyp element : zabbix vm.snapshoot.get
    Zabbix return to me "unsupported item key" because
    I already downloaded and install vmware template from : https://git.zabbix.com/projects/ZBX/...2FDEV-2376-6.0
    I have zabbix 6.0, but i cannot found any vmware vm.snapshoot.get in the template
    Where is the template for found "vm.snapshoot.get" ?
    Where did you find such thing as "vm.snapshoot.get" ?
    Only place I can see anything about snapshots (and not snapshoots) is in VM discovery field list.. https://www.zabbix.com/documentation...scovery_fields
    {#VM.SNAPSHOT.COUNT} Number of VM snapshots.
    If you cannot see it being used in any of prototypes, then maybe it is just not made into any of OOB items/triggers. You have an option to use it in your own items...
    • BlockSto
      • Apr 2024
      • 12
      From VMware template, In Discover VMware VMs I see nothing about VM.SNAPSHOT.COUNT when i try to create an prototyp element(simple check), same way when i try to create an item (simple check)
      • BlockSto
        • Apr 2024
        • 12
        ok its fix, i got zabbix 6.0 and it still available for zabbix 6.4
