How to prevent reopening of allerts
  • matzefratze81
    • Jan 2024
    • 10
    i have some triggers that reopen when i manually close them.
    Example:
    last(/Proxmox01/proxmox.qemu.vmstatus[qemu/100])<>"running"
    Or: Disk read request responses are too high
    Or memory over 80 % or something like this.
    I know this but i want to close the problem. How i have to modify the trigger that i can close the problem?
  • kyus
    • Feb 2024
    • 203
    Maybe you should consider taking a look at the thresholds for those triggers and adapt them accordingly to your environment.
    If you just want to ignore those triggers for some time, you could use the suppress option in the problem update menu. But, if I'm not mistaking, that's only available for Zabbix 6.2.x and above.
