ICMP Ping Trigger from template
  • foxshade
    • Apr 2024
    One of the trigger that comes with Template Module ICMP Ping is "Unavailable by ICMP ping"
    Expression:
    max(/Template Module ICMP Ping/icmpping,#3)=0
    AFAIK, it means when the max value of 3 subsequent icmpping is 0, it will activate the trigger.
    Now, if I were to create another trigger so it would send out email after 15 minutes of icmpping 0 such as:
    max(/Template Module ICMP Ping/icmpping,15m)=0
    or
    min(/Template Module ICMP Ping/icmppingloss,15m)=100
    or
    avg(/Template Module ICMP Ping/icmppingloss,15m)=100
    All the above triggers activate at the same time as max(/Template Module ICMP Ping/icmpping,#3)=0
    What gives?
