Dashboard - Top Hosts - 'Less than' Thresholds
  • supertramp4
    • Sep 2023
    Using Zabbix 6.4.13 ( appliance) , i am monitoring number of hosts using ICMP, which returns 0 = Down, and 1=Up
    In the Dashboard widget - "Top Hosts", currently the "Thresholds" only seems to work if the value is Greater than is ?
    Is there a way to set a Threshold which is LESS THAN, so that I can Highlight the Ping "Down" value of Zero so as to mark the column as RED
    Many Thanks
  • Answer selected by supertramp4 at 09-04-2024, 15:37.
    cyber
    Set base color to "red" and leave that "green" at 0.1
      • supertramp4
        • Sep 2023
        Thanks Cyber - Thank you so much - That looks lovely now !.
