Script Item not compiling
  • AKC99
    • Feb 2024
    I'm very new to Zabbix and trying to make a script item so I can write to a coil on my device with SNMP. So, I need to use snmpset to write 1 to the coil's OID to do the action detailed in the coil. When I test my item, I get and error saying: "Cannot compile script: SyntaxError: unterminated statement (line 1)". This is my first time trying to make a script item and I can't find anything about this error message in the forums. Here is my script setup and test:
    Click image for larger version  Name:	image.png Views:	0 Size:	144.1 KB ID:	482186
    Click image for larger version  Name:	image.png Views:	0 Size:	77.5 KB ID:	482185
    Script type means JavaScript, not bash or something else... https://www.zabbix.com/documentation...emtypes/script
    • AKC99
      • Feb 2024
      I was following the examples in that manual which is how I got this far. I guess because I don't know JavaScript, I'm don't understand why my script does not compile.
        You did not write any JS.... As long as I can see, you entered snmpset .... there which is a command line tool and has nothing to do with JS...
        • AKC99
          • Feb 2024
          I see what you mean now. Again I'm really new to Zabbix so when I saw this forum: https://www.zabbix.com/forum/zabbix-...et-with-zabbix talking about using snmpset in scripts in Zabbix, I thought it was talking about item scripts as that was the only type of scripts I found in the appliance. Looking more at JavaScript I don't know if it's feasible to write to my SNMP items in JSON. Is there any other way to write to my SNMP items in the appliance?
          • Weni
            • Sep 2022
            Hi
            Have you solvd the Problem with SNMPSET.
            I want also set a Automatique to Restart my AP's.
