How to enable zabbix 2FA and will affect my api users
Can you help me to configure Zabbix with 2FA enabled with Google authenticator? Also, can you clarify when enabling 2fa that will affect API users too? Suppose Grafana is fetching the Zabbix data from API. Can any one please help
