The ability to monitor the physical ports of a client's machine
  • lisanovak
    • Feb 2024
    Hello, I'm curious about Zabbix and its features. Specifically, does it offer the ability to monitor the physical ports of a client's machine? For instance, can it detect when HDMI cables are connected or disconnected? How straightforward is it to set up such monitoring, or is it a complex process? I appreciate any insights you can provide. Thank you.
    • 4993
    Think, if you can do it somehow on that machine manually (without looking on cables)... Then it maybe can be scripted and then it can be executed with UserParameters and you can get your data.
