Is it possible to get the data from old zabbix-agent with zabbix 6.4 or higher?
  • CSYI
    • Apr 2024
    Hello there,
    I wish to know about get the data from old zabbix-agent with Zabbix 6.4 or higher.
    Is it possible to get data as below?
    <Environment>
    Zabbix Ver. 6.4
    Zabbix-agent Ver. 4.0
    <Wish to get the data>
    Map(for Geomap)
    Inventory
  • Answer selected by CSYI at 18-04-2024, 02:00.
    kyus
    • Feb 2024
    • 198
    Hello!
    Yes, it'll work. Zabbix Server 6.4 supports Zabbix Agent 1.4+
    Here's the documentation:
    • kyus
      kyus commented
      I'm just a bit confused about what you meant with get the data for Geomap and inventory
    • CSYI
      CSYI commented
      I have concerned about whether information can be obtained correctly with the old Zabbix-agent for the Geomap and inventory functions implemented in the current Zabbix version.
      Thx.
    • kyus
      kyus commented
      Well, the information comes from items, so if your items are supported, everything should work just fine. You can always test it with zabbix_get, it's pretty useful
  • kyus
    • Feb 2024
    • 198
    Hello!
    • kyus
      kyus commented
    • CSYI
      CSYI commented
      Thx.
    • kyus
      kyus commented
