Top Hosts widget excluding host when other hosts added?
  • SkilledAlpaca
    • May 2023
    • 24
    Zabbix Version: 6.4
    Template: Latest Synology DiskStation SNMPv3
    NAS Models: DS418, DS220+, DS920+ (red one in screenshots)
    DSM Version: 7.2
    I am attempting to create a simple Top Hosts widget to monitor these three NAS current capacity but I am running into a strange issue. When I put the DS920 into the widget alone using the key provided from the DS920, it works perfectly fine. As soon as I add the DS418 and DS220 along side it, the DS920 disappears from the list. I have the 'Host Count' set to '4' and the widget is expanded enough to show three hosts, so that doesn't appear to be the issue.
    The left widget has all three NAS selected, but only the DS920 is missing. The widget on the right only includes the DS920 using the same key, I just didn't format the bar colors :P
    The key for the DS418 and DS220 is 'host.hrStorage.hrStorageTable.hrStorageEntry.hrSt orageUsed[53,pct]' while the DS920 is 'host.hrStorage.hrStorageTable.hrStorageEntry.hrSt orageUsed[57,pct]' but strangely enough, both keys present the same problem.
    Any insight or help into figuring this out would be greatly appreciated! It's not end of the world but the problem itself is perplexing me and I would like to get it resolved. Thank you in advance!
  • DEV2DEV
    • Apr 2024
    Possible workaround:
    You could create dependent items and give all of them the same key.
    I had the same problem with CPU utilization for windows and linux machines. Different keys for the same values.
    • SkilledAlpaca
      • May 2023
      • 24
      That's an interesting workaround that I may look into doing in the meantime. I could probably utilize that to make a proper combined top hosts widget for a couple other things I have on other various dashboards. Thank you!
      I would still like to find a standard solution to this if possible though.
