Encrypt the password in Web Monitoring
  • Filter
    Hi All,
    Please tell me , how to use encrypted password when create the web scenario.
    Or any other way to mask the password while creating the web scenario.
    Please guide me.
    Thanks,
    Subbiah Kumar
    What version are using?
    If you want mask web views,
    I think to check the files of each of the view may be changed CTextBox to CPassBox.
    Please check the PHP file under the include/views directory.
      HI Atsushi,
      I am using Zabbix 3.0.
      Please tell me where I can change.
        If someone else is still struggling with this, here is how to do it for Zabbix 3.4.2. Atsushi's directions were good, however not 100% clear . You indeed need to go to /usr/share/zabbix/include/views configuration.httpconf.edit.php and later change the following line:
        (new CTextBox('http_password', $this->data['http_password'], false, 64))
        to:
        (new CPassBox('http_password', $this->data['http_password'], false, 64))
        Et voilĂ  !
        Announcement
        No announcement yet.
