I have strange situation:
My Zabbix 3.0.1 calculates item values perfectly and "as schedulled", but for some items triggers doesnt recalculates or calculates incorrectly.
For example, i have metric/item called "Cluster status", and it contains the word "green". But trigger, which checks equality of this word to "red", was calculated to "1". When i update table "triggers" in zabbix database directly (execute UPDATE statement) and set the value of the trigger to "0" - trigger did not turns to "1" again.
Before 06.11 all works properly with this triggers and items (nothing was added to zabbix).
Because there is no "last_clock" or so in the "triggers" table - i cant make it clear, when the trigger was calculated last time. Maybe its "problem" state is for 06.11, but last item value was collected at 08/11? - who knows
I'm in doubt, what to do: there are many (>10) triggers which "sticks on" "problem" value and never turns to "ok" itself, but keep its "ok" value if i set it by hand in db.
Anybody, help me, please. Maybe, you have some ideas, why trigger value may not appropriate to its corresponding item value?
Thank you very much!
