HW model as tag on the host
  • akimdarov
    • Mar 2020
    Hi *,
    Is there any convenient way to add the host info {INVENTORY.MODEL} to a tag "Model" = {INVENTORY.MODEL} on a host?
    Preferably on the template level.
    I would like to see just some specific models on a bios version dashboard - based on said tag.
    {INVENTORY.MODEL} seems not to be expanded when I add it to the tags and just stays there as a text string.
    (Zabbix Server and Agent v6.4.13)
    Cheers!
    Adding such tag on template level will add that tag to events produced by triggers in that template.. You cannot use those for selecting hosts in widget..
    It will only work, if your hosts have host level tags with specific value, not pointing to inventory value..
