Multiple Zabbix problems
  • Mishusik
    • Apr 2024
    Hi
    I had Zabbix 6.2 and everything was ok, recently I upgraded to 6.4.12 and since then I have had multiple problems.
    Zabbix server: Utilization of housekeeper processes over 75%
    Zabbix server: Utilization of configuration syncer processes over 75%
    Zabbix server: Utilization of poller processes over 75%
    Zabbix server: Utilization of preprocessing manager processes over 75%
    sda: Disk read/write request responses are too high (read > 20 ms for 15m or write > 20 ms for 15m)
    Zabbix server: Utilization of history syncer processes over 75%
    On Zabbix 6.2 I didn't have any SQL configuration since the upgrade I made some changes
    I'm attaching all the settings, do you have some suggestions for me, please?
    My server is
    8 CPU and 32 GIG RAM
    I use Centos 8 with MySQL and Apache
    my zabbix config is :
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=512
    PidFile=/run/zabbix/zabbix_server.pid
    SocketDir=/run/zabbix
    DBName=zabbix
    StartPollers=20
    StartIPMIPollers=10
    StartPreprocessors=20
    StartPollersUnreachable=20
    StartHistoryPollers=20
    StartTrappers=20
    StartPingers=20
    StartDiscoverers=20
    StartVMwareCollectors=5
    VMwarePerfFrequency=60
    VMwareCacheSize=256M
    VMwareTimeout=10
    StartSNMPTrapper=1
    HousekeepingFrequency=2
    MaxHousekeeperDelete=50000
    CacheSize=1G
    StartDBSyncers=10
    HistoryCacheSize=128M
    HistoryIndexCacheSize=64M
    ValueCacheSize=1G
    Timeout=4
    LogSlowQueries=3000
    StatsAllowedIP=127.0.0.1
    StartODBCPollers=10​
    my SQL conf is :
    [client-server]
    !includedir /etc/my.cnf.d
    open_files_limit = 16364
    max_connections = 500
    event_scheduler = 1
    wait_timeout = 86400
    default_storage_engine = InnoDB
    log_error = /var/log/mysql/mysqld-error.log
    slow_query_log_file = /var/log/mysql/mysqld-slow.log
    general_log_file = /var/log/mysql/mysqld.log
    general_log = 0
    skip-name-resolve = 1
    performance_schema = ON
    innodb_buffer_pool_size=23G
    innodb_buffer_pool_instances=12
    innodb_buffer_pool_dump_at_shutdown=1
    innodb_buffer_pool_load_at_startup=1
    innodb_log_file_size=512M
    innodb_flush_method=O_DIRECT
    innodb_flush_log_at_trx_commit=0
    query_cache_size=0
    thread_cache_size=64
    tmp_table_size = 134217728
    table_open_cache = 2048
    join_buffer_size = 262144
    binlog-row-event-max-size = 8192
    character_set_server = utf8
    collation_server = utf8_bin
    expire_logs_days = 1
    max_allowed_packet = 32M
    query_cache_type = 0
    slow-query-log = ON
    thread_pool_size = 12
    optimizer_switch = 'index_condition_pushdown=off'
    innodb_autoinc_lock_mode = 2
    innodb_autoextend_increment = 256
    innodb_change_buffer_max_size = 50
    innodb_concurrency_tickets = 5000
    innodb_file_per_table = 1
    query_cache_limitinnodb_log_files_in_group = 4
    innodb_old_blocks_time = 1000
    innodb_open_files = 2048
    innodb_stats_on_metadata = OFF
    innodb_lock_wait_timeout = 50
    innodb_io_capacity = 2000
