Prototype Item is not working but manual Item with same Parameters is
  • marcohald
    • Apr 2024
    I try to get the modified timestamp of the Files via a Discovery Rule that depends on filesystem listing.
    the manual created item is working without an issue, but the prototype item is only created and no data could be get for it.
    I have no Idea why it is working when manually created, but not as item prototype
    [{"basename":"columnstore","pathname":"/srv/mysqldumps/nightly/columnstore","dirname":"/srv/mysqldumps/nightly","type":"dir","user":"mysql","group":"adm","permissions":"2775","uid":111,"gid":4,"size":4096,"time":{"access":"2024-04-19T12:11:42+0200","modify":"2024-04-19T12:11:42+0200","change":"2024-04-19T12:40:09+0200"},"timestamp":{"access":1713521502,"modify":1713521502,"change":1713523209}},{"basename":"zabbix.sql.gz","pathname":"/srv/mysqldumps/nightly/zabbix.sql.gz","dirname":"/srv/mysqldumps/nightly","type":"file","user":"root","group":"adm","permissions":"0660","uid":0,"gid":4,"size":3564615,"time":{"access":"2024-04-19T12:44:03+0200","modify":"2024-04-19T12:44:05+0200","change":"2024-04-19T12:44:05+0200"},"timestamp":{"access":1713523443,"modify":1713523445,"change":1713523445}}]
    Error:
    Preprocessing failed for: [{"basename":"columnstore","pathname":"/srv/mysqldumps/nightly/columnstore","dirname":"/srv/mysql...
    1. Failed: cannot extract value from json by path "$..[?(@.basename == "{#STATUSFILE}")].timestamp.modify": no data matches the specified path
    ​​Click image for larger version
    This is my template:
        "zabbix_export": {
            "version": "6.4",
            "template_groups": [
                    "uuid": "748ad4d098d447d492bb935c907f652f",
                    "name": "Templates/Databases"
            "templates": [
                    "uuid": "5a04d103d92f431a8ed37f122f02aac1",
                    "template": "filewatcher-test",
                    "name": "filewatcher-test",
                    "groups": [
                    "items": [
                            "uuid": "8e7558bda9604e46849d8ae459d3ae9d",
                            "name": "manual zabbix.sql.gz",
                            "type": "DEPENDENT",
                            "key": "a.test.1",
                            "delay": "0",
                            "preprocessing": [
                                    "type": "JSONPATH",
                                    "parameters": [
                                        "$..[?(@.basename == \"zabbix.sql.gz\")].timestamp.modify"
                                    "type": "LTRIM",
                                    "parameters": [
                                    "type": "RTRIM",
                                    "parameters": [
                            "master_item": {
                                "key": "vfs.dir.get[/srv/mysqldumps/nightly/]"
                            "tags": [
                                    "tag": "Application",
                                    "value": "Test-MySQL"
                            "uuid": "2ce61f7133c5404e9c6f8e450fdfa75d",
                            "name": "Filesystem list /srv/mysqldumps/nightly/",
                            "key": "vfs.dir.get[/srv/mysqldumps/nightly/]",
                            "history": "7d",
                            "trends": "0",
                            "value_type": "TEXT",
                            "tags": [
                    "discovery_rules": [
                            "uuid": "04ee44644853462c916231f0238762c3",
                            "name": "Automatic discovery test",
                            "key": "discovery.files.srv.mysqldumps.nightly",
                            "delay": "0",
                            "item_prototypes": [
                                    "uuid": "beea433e672b40c1ba68c447c4510be6",
                                    "name": "automatic {#BASENAME}",
                                    "key": "statusfile.modified.timestamp[{#BASENAME}]",
                                    "delay": "0",
                                    "trends": "0",
                                    "preprocessing": [
                                            "type": "JSONPATH",
                                            "parameters": [
                                                "$..[?(@.basename == \"{#STATUSFILE}\")].timestamp.modify"
                                            "type": "LTRIM",
                                            "parameters": [
                                            "type": "RTRIM",
                                            "parameters": [
                                    "master_item": {
                                    "tags": [
                            "master_item": {
                            "lld_macro_paths": [
                                    "lld_macro": "{#BASENAME}",
                                    "path": "$.basename"
                                    "lld_macro": "{#MODIFY}",
                                    "path": "$.timestamp.modify"
                                    "lld_macro": "{#SIZE}",
                                    "path": "$.size"
                            "preprocessing": [
                                    "type": "DISCARD_UNCHANGED_HEARTBEAT",
                                    "parameters": [
                                        "1d"
    {#STATUSFILE} .. it has no value.. Shouldn't there be {#BASENAME} instead? jsonpath is evil..
