Database mismatch
  • it.tech
    • May 2021
    • 28
    Database mismatch
    Hello folks,
    I'm in the insane situation, perhaps it has been experienced and reported by many Zabbix users but I failed to find a clear explanation and advice on what to do.
    Installed Zabbix on the recent Fedora 39 server. Everything was downloaded from the current and active repository.
    Zabbix server starts and runs, no issues, but an attempt to start web based installation complains about the database version:
    The Zabbix database version does not match current requirements. Your database version: 6000000. Required version: 6040000. Please contact your system administrator.
    What's wrong, I imported SQL files from /usr/share/zabbix-mysql, right where Zabbix is installed by running yum/dnf.
    The server version is Zabbix 6.0.27, why would it require db version higher ?
    How will I upgrade the database ?
    • 4993
    Check carefully what is installed... Frontend files from 6.4?
    • it.tech
      • May 2021
      • 28
      I guess so, but I ended up rebuilding the whole server and installed Zabbix on Ubuntu, not on Fedora.
