Discovery of host interfaces in Zabbix for linux host
  • mbld
    • Apr 2024
    I am new to zabbix and I could need some help on this documentation :
    I am trying to get informations from a linux server (Debian 10) : All of the host's configured interfaces (name +IP).
    As Zabbix retrieves the IP of each host, it is only the IP of which the agent is configured to listen on.
    I am looking for a way to get the same result as "net.if.list" but this is only available for windows hosts.
    I tried to make a new template in which I have only created a discovery rule. In this discovery rule I have set it up like this :
    Type : Zabbix Agent
    Key : zabbix[host,discovery,interfaces]
    I have tried to test this discovery rule on a linux host with it's IP and the default zabbix agent port.
    The result of the test is the following : Unsupported item key
    The zabbix server version is 6.0, the targeted host is already monitored in Zabbix and by its default port.
    Is it possible that something is missing on the server ?
    If I cannot use that builtin zabbix discovery key, should scripting be involved for fetching a JSON ?
  • Answer selected by mbld at 22-05-2024, 13:38.
    mbld
    • Apr 2024
    Hello
    I am happy to say I have found a way to achieve what I was looking for.
    I followed this doc : https://www.zabbix.com/documentation...xtending_agent
    And I configured my zabbix agent on the monitored machine to have custom keys for what I am looking for.
    /etc/zabbix/zabbix_agentd.conf
    UserParameter=ip.allinterfaces,ip -br -f inet addr | awk '{print $1, $3}'
    UserParameter=lsof.listeningservice,lsof -i -P -n | grep LISTEN | awk '{print $1, $9}'
      Whats wrong with manual? https://www.zabbix.com/documentation...t#network-data
      net.if.discovery
      List of network interfaces. Used for low-level discovery.
      • mbld
        • Apr 2024
        Hello Cyber,
        net.if.discovery would output something like this :
        [{"{#IFNAME}":"lo"},{"{#IFNAME}":"enp1s0f0"},{"{ #IF NAME}":"enp1s0f1"}]
        It's almost what I want, there are the interfaces but no IP addr associated to them shown.
        I made a little bit of research and found that ticket, which is the feature I'm exactly looking for :
        It seems like this feature was never added to Zabbix and the author of this ticket is inactive since 2016.
        It would be nice to rely on Zabbix for this purpose in a simple way, how would it be like ?
        • mbld
          • Apr 2024
          Hello
