Need help setting up zabbix as trap receiver
  • tjernigan
    • Apr 2024
    I have been following the instructions as laid out in this walkthrough https://reasonableitservice.com/setu...n-zabbix-v6-4/
    But I'm stuck. I can't get snmptrapd running. I have a fresh install of ubuntu and zabbix setup. I don't even have any hosts yet. When I attempt to start snmptrapd I get this error
    not sure how to resolve it
    Loaded: loaded (/lib/systemd/system/snmptrapd.service; static)
    Active: failed (Result: exit-code) since Fri 2024-04-26 16:51:47 UTC; 7s ago
    TriggeredBy: ● snmptrapd.socket
    Process: 2714 ExecStart=/usr/sbin/snmptrapd -LOw -f udp:162 udp6:162 (code=exited, status=255/EXCEPTION)
    Main PID: 2714 (code=exited, status=255/EXCEPTION)
    CPU: 32ms
    Apr 26 16:51:47 Zabbix systemd[1]: Starting Simple Network Management Protocol (SNMP) Trap Daemon....
    Apr 26 16:51:47 Zabbix snmptrapd[2714]: Unrecognized character \xE2; marked by <-- HERE after do <-- HERE near column 4 at (eval 6) line 1.
    Apr 26 16:51:47 Zabbix systemd[1]: snmptrapd.service: Main process exited, code=exited, status=255/EXCEPTION
    Apr 26 16:51:47 Zabbix systemd[1]: snmptrapd.service: Failed with result 'exit-code'.
    Apr 26 16:51:47 Zabbix systemd[1]: Failed to start Simple Network Management Protocol (SNMP) Trap Daemon..
  • tim.mooney
    • Dec 2012
    • 1432
    You have an invalid character (it's hex byte E2) in your snmptrapd.conf or other SNMP configuration file that you edited. The invalid character is somewhere after the word "do " in the file.
    Did you edit snmptrapd.conf with a Windows editor? Did you cut-and-paste from a web page? Have you made any changes to your locale-related settings (like LANG) on that system?
    Somehow you managed to get garbage text into the config file, but it's not clear how that would happen under normal circumstances.
