Zabbix installation problem
  • Ayow
    • Apr 2024
    Hello zabbix community,
    i'm installing zabbix in its latest version on a debian 12 machine, and when i get to the settings via “zabbix.php” i get stuck there like on the screenshot without having the other config options, can someone help me on this please?
    Thank you
    Regards​
  • Pierre31300
    • Dec 2024
    hi, i have the same problem too. Do you find a solution?
    • NgRox
      • Jun 2022
      • 45
      I recommend decreasing the screen, the button should be lower.
      • Pierre31300
        • Dec 2024
        Hi, someone help me
        You can find solution here
        Probleme installation de zabbix 7.0.5 - ZABBIX Forums
