Ask for HTTP API
  • smithloo
    • Apr 2024
    Ask for HTTP API
    I would like monitoring an API endpoint,
    I would like to set up an alert if the duration time is larger than 20, or there is any exception, or status is not "OK". Unfortunately, I have no idea how to do that in Zabbix.
    I couldn't work it out,
    I hope someone can help me
  • Brambo
    • Jul 2023
    • 250
    Create an Item, type http agent.
    Point it to the API address and do something with the data output.
    Later make a Trigger, select your item and result > 20
    • smithloo
      • Apr 2024
      thanks brambo
