IIS Application Pool Request/Sec and Transactions/Sec
  • Indalecio_Trujillo
    • May 2024
    I have created these items to obtain these performance counters values.
    IIS: AppPool {#APPPOOL} Transactions/Sec perf_counter_en["\ASP.NET Applications({#APPPOOL})\Transactions/Sec"]
    IIS: AppPool {#APPPOOL} Request/Sec perf_counter_en["\ASP.NET Applications({#APPPOOL})\Requests/Sec"]
    but im getting this message on zabbix
    "Cannot obtain performance information from collector."
    I have added these items in application pools discovery.
    Any idea why I'm getting this error message?
    Might be, that those perf counters are not enabled on host...
      Indalecio_Trujillo commented
      Yes, the perf counter exist on server i can see using performance monitor
    Then I have no idea.. Too few experience with perf metrics...
    • PeterZielony
      • Nov 2022
      • 146
      iis management scripts and tools installed?
      Hiring in the UK? Drop a message
      • amjelnes
        • May 2014
        Not sure it's related but I just had an issue with two servers of 4 identical servers where for some reason perf counters failed on the two.
        When opening perf monitor on the affected servers I would get an error pop up.
        Fix was:
        cmd elevated:
         cd c:\windows\system32
          lodctr /R
            cd c:\windows\sysWOW64
          lodctr /R
        If any errors when you run those commands run them once more.
        After restarting agent service, data started flowing again and errors went away
