I have a Windows Event Monitor configure and on latest data I see an error saying that it is only available as an active check. I have gone over my config file and I believe I have everything enabled that is needed but it is still not running. I have already restarted the agent services. I have opened ports 10050 and 10051 in the firewall of the server and agent. What am I missing?
Config File:
Config File:
# This is a configuration file for Zabbix agent service (Windows)
# To get more information about Zabbix, visit http://www.zabbix.com
### Option: LogType
# Specifies where log messages are written to:
# system - Windows event log
# file - file specified with LogFile parameter
# console - standard output
# Mandatory: no
# Default:
# LogType=file
### Option: LogFile
# Log file name for LogType 'file' parameter.
# Mandatory: no
# Default:
# LogFile=
LogFile=c:\program files\Zabbix Agent\zabbix_agentd.log
### Option: LogFileSize
# Maximum size of log file in MB.
# 0 - disable automatic log rotation.
# Mandatory: no
# Range: 0-1024
# Default:
# LogFileSize=1
### Option: DebugLevel
# Specifies debug level:
# 0 - basic information about starting and stopping of Zabbix processes
# 1 - critical information
# 2 - error information
# 3 - warnings
# 4 - for debugging (produces lots of information)
# 5 - extended debugging (produces even more information)
# Mandatory: no
# Range: 0-5
# Default:
# DebugLevel=3
### Option: SourceIP
# Source IP address for outgoing connections.
# Mandatory: no
# Default:
# SourceIP=
### Option: EnableRemoteCommands
# Whether remote commands from Zabbix server are allowed.
# 0 - not allowed
# 1 - allowed
# Mandatory: no
# Default:
EnableRemoteCommands=1
### Option: LogRemoteCommands
# Enable logging of executed shell commands as warnings.
# 0 - disabled
# 1 - enabled
# Mandatory: no
# Default:
LogRemoteCommands=1
##### Passive checks related
### Option: Server
# List of comma delimited IP addresses (or hostnames) of Zabbix servers.
# Incoming connections will be accepted only from the hosts listed here.
# If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally.
# Mandatory: no
# Default:
# Server=
Server=x.x.x.61
### Option: ListenPort
# Agent will listen on this port for connections from the server.
# Mandatory: no
# Range: 1024-32767
# Default:
ListenPort=10050
### Option: ListenIP
# List of comma delimited IP addresses that the agent should listen on.
# First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
# Mandatory: no
# Default:
# ListenIP=0.0.0.0
### Option: StartAgents
# Number of pre-forked instances of zabbix_agentd that process passive checks.
# If set to 0, disables passive checks and the agent will not listen on any TCP port.
# Mandatory: no
# Range: 0-100
# Default:
# StartAgents=3
##### Active checks related
### Option: ServerActive
# List of comma delimited IP:port (or hostname:port) pairs of Zabbix servers for active checks.
# If port is not specified, default port is used.
# IPv6 addresses must be enclosed in square brackets if port for that host is specified.
# If port is not specified, square brackets for IPv6 addresses are optional.
# If this parameter is not specified, active checks are disabled.
# Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
# Mandatory: no
# Default:
# ServerActive=
ServerActive=x.x.x.61
### Option: Hostname
# Unique, case sensitive hostname.
# Required for active checks and must match hostname as configured on the server.
# Value is acquired from HostnameItem if undefined.
# Mandatory: no
# Default:
# Hostname=
### Option: HostnameItem
# Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
# Does not support UserParameters or aliases.
# Mandatory: no
# Default:
HostnameItem=system.hostname
### Option: HostMetadata
# Optional parameter that defines host metadata.
# Host metadata is used at host auto-registration process.
# An agent will issue an error and not start if the value is over limit of 255 characters.
# If not defined, value will be acquired from HostMetadataItem.
# Mandatory: no
# Range: 0-255 characters
# Default:
# HostMetadata=
### Option: HostMetadataItem
# Optional parameter that defines an item used for getting host metadata.
# During an auto-registration request an agent will log a warning message if
# the value returned by specified item is over limit of 255 characters.
# This option is only used when HostMetadata is not defined.
# Mandatory: no
# Default:
# HostMetadataItem=
### Option: RefreshActiveChecks
# How often list of active checks is refreshed, in seconds.
# Mandatory: no
# Range: 60-3600
# Default:
RefreshActiveChecks=120
### Option: BufferSend
# Do not keep data longer than N seconds in buffer.
# Mandatory: no
# Range: 1-3600
# Default:
# BufferSend=5
### Option: BufferSize
# Maximum number of values in a memory buffer. The agent will send
# all collected data to Zabbix server or Proxy if the buffer is full.
# Mandatory: no
# Range: 2-65535
# Default:
# BufferSize=100
### Option: MaxLinesPerSecond
# Maximum number of new lines the agent will send per second to Zabbix Server
# or Proxy processing 'log', 'logrt' and 'eventlog' active checks.
# The provided value will be overridden by the parameter 'maxlines',
# provided in 'log', 'logrt' or 'eventlog' item keys.
# Mandatory: no
# Range: 1-1000
# Default:
# MaxLinesPerSecond=20
############ ADVANCED PARAMETERS #################
### Option: Alias
# Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
# Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
# Different Alias keys may reference the same item key.
# For example, to retrieve paging file usage in percents from the server:
# Alias=pg_usage:perf_counter[\Paging File(_Total)\% Usage]
# Now shorthand key pg_usage may be used to retrieve data.
# Aliases can be used in HostMetadataItem but not in HostnameItem or PerfCounter parameters.
# Mandatory: no
# Range:
# Default:
### Option: Timeout
# Spend no more than Timeout seconds on processing.
# Mandatory: no
# Range: 1-30
# Default:
# Timeout=3
### Option: PerfCounter
# Syntax: <parameter_name>,"<perf_counter_path>",<period>
# Defines new parameter <parameter_name> which is an average value for system performance counter <perf_counter_path> for the specified time period <period> (in seconds).
# For example, if you wish to receive average number of processor interrupts per second for last minute, you can define new parameter "interrupts" as following:
# PerfCounter = interrupts,"\Processor(0)\Interrupts/sec",60
# Please note double quotes around performance counter path.
# Samples for calculating average value will be taken every second.
# You may run "typeperf -qx" to get list of all performance counters available in Windows.
# Mandatory: no
# Range:
# Default:
### Option: Include
# You may include individual files in the configuration file.
# Mandatory: no
# Default:
# Include=
# Include=c:\zabbix\zabbix_agentd.userparams.conf
# Include=c:\zabbix\zabbix_agentd.conf.d\
# Include=c:\zabbix\zabbix_agentd.conf.d\*.conf
### Option: UnsafeUserParameters
# Allow all characters to be passed in arguments to user-defined parameters.
# The following characters are not allowed:
# Additionally, newline characters are not allowed.
# 0 - do not allow
# 1 - allow
# Mandatory: no
# Range: 0-1
# Default:
# UnsafeUserParameters=0
### Option: UserParameter
# User-defined parameter to monitor. There can be several user-defined parameters.
# Format: UserParameter=<key>,<shell command>
# Mandatory: no
# Default:
# UserParameter=
UserParameter=services.NTDS,net start NTDS
####### TLS-RELATED PARAMETERS #######
### Option: TLSConnect
# How the agent should connect to server or proxy. Used for active checks.
# Only one value can be specified:
# unencrypted - connect without encryption
# psk - connect using TLS and a pre-shared key
# cert - connect using TLS and a certificate
# Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
# Default:
# TLSConnect=unencrypted
### Option: TLSAccept
# What incoming connections to accept.
# Multiple values can be specified, separated by comma:
# unencrypted - accept connections without encryption
# psk - accept connections secured with TLS and a pre-shared key
# cert - accept connections secured with TLS and a certificate
# Default:
# TLSAccept=unencrypted
### Option: TLSCAFile
# Full pathname of a file containing the top-level CA(s) certificates for
# peer certificate verification.
# Mandatory: no
# Default:
# TLSCAFile=
### Option: TLSCRLFile
# Full pathname of a file containing revoked certificates.
# Mandatory: no
# Default:
# TLSCRLFile=
### Option: TLSServerCertIssuer
# Allowed server certificate issuer.
# Mandatory: no
# Default:
# TLSServerCertIssuer=
### Option: TLSServerCertSubject
# Allowed server certificate subject.
# Mandatory: no
# Default:
# TLSServerCertSubject=
### Option: TLSCertFile
# Full pathname of a file containing the agent certificate or certificate chain.
# Mandatory: no
# Default:
# TLSCertFile=
### Option: TLSKeyFile
# Full pathname of a file containing the agent private key.
# Mandatory: no
# Default:
# TLSKeyFile=
### Option: TLSPSKIdentity
# Unique, case sensitive string used to identify the pre-shared key.
# Mandatory: no
# Default:
# TLSPSKIdentity=
### Option: TLSPSKFile
# Full pathname of a file containing the pre-shared key.
# Mandatory: no
# Default:
# TLSPSKFile=
