MS Teams update previous post?
  • BMaltbieQGC
    • Jan 2024
    Hi, I have recently enabled the MS Teams Media type, the connector is working but I noticed the "resolved" messages don't update the previous post - they create a new post. Is this normal behavior? We are migrating to Teams from Slack, and the Zabbix Slack connector doesn't behave this way. In Slack, a problem message will post with an orange color code, then later when the problem is resolved, the same entry is modified and color coded green. This is handy as you can quickly browse the channel and you know all the orange posts haven't been resolved yet. For the Teams connector, it creates an orange "problem" post, then later creates a separate green "resolved" post. So browsing the channel you see all the orange posts whether they have been resolved or not. I was just wondering if this is a known limitation with Teams Connector. Thank you!
  • incama
    • Jan 2015
    • 66
    Following this thread as it would be a nice feature!
