log monitoring won't work
  • amit.z
    • May 2024
    Hey,
    I try to monitor some logs and look for a specific pattern inside the log.
    - I am creating a new item
    - Type: Zabbig-agent(active)
    - I choose key: log[/var/log/syslog,]
    - I set the interval for 1s and save the item.
    Then, when I check the latest data, I don't see any logs entry.
    I tried to play with this but nothing works for me,
    This is 1 example that I found that I tried to copy it: https://www.youtube.com/watch?v=Ny_UaGF1Cr8
    It didn't work.
    If someone have any idea...
    thx!
  • vijayk
    • May 2023
    • 305
    To monitor log file zabbix user must have read access to this file. Please verify it.
