Issue installing Zabbix6 agent on Rocky Linux 8
  • Rohaldos
    • May 2024
    I am experiencing some problems with never happened before. When I install zabbix6 agent (not agent2) on Rocky Linux it does create the /etc/zabbix but the configuration file is in /etc. I did install zabbix agent6 on CentOS7 never had this problem.
    If I install zabbix6 agent2 the configuration file gets created in /etc/zabbix/
    My question is this a normal behaviour for installing zabbix6 agent on Rocky Linux 8?
    Kind Regards,
    Antonio
  • Rohaldos
    • May 2024
    Quick update
    I updated the zabbix-agent.service to the following and moved the zabbix_agentd.conf to /etc/zabbix
    ExecStart=/usr/sbin/zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf -f
    I still don't understand why the zabbix agent installation process would create the /etc/zabbix and put the zabbix_agentd.conf in /etc.
    Kind Regards,
    Antonio
    • tim.mooney
      • Dec 2012
      • 1432
      That sounds like a packaging bug. What version of the zabbix-agent package, specifically, did you download?
      I just checked the 6.0.29-release1.el8 RPM and it looks correct. zabbix-agent.conf is packaged in /etc/zabbix/
      $ rpm -q -l -p zabbix-agent-6.0.29-release1.el8.x86_64.rpm
      warning: zabbix-agent-6.0.29-release1.el8.x86_64.rpm: Header V4 RSA/SHA512 Signature, key ID a14fe591: NOKEY
      /etc/logrotate.d/zabbix-agent
      /etc/zabbix/zabbix_agentd.d
      /usr/lib/.build-id
      /usr/lib/.build-id/b7
      /usr/lib/.build-id/b7/8a50a77f84fcba17b5d3a3adc23432efac9a3d
      /usr/lib/systemd/system/zabbix-agent.service
      /usr/lib/tmpfiles.d/zabbix-agent.conf
      /usr/share/doc/zabbix-agent
      /usr/share/doc/zabbix-agent/AUTHORS
      /usr/share/doc/zabbix-agent/COPYING
      /usr/share/doc/zabbix-agent/ChangeLog
      /usr/share/doc/zabbix-agent/NEWS
      /usr/share/doc/zabbix-agent/README
      /usr/share/doc/zabbix-agent/userparameter_mysql.conf
      /usr/share/man/man8/zabbix_agentd.8.gz
      /var/log/zabbix
      /var/run/zabbix
      • Rohaldos
        • May 2024
        /usr/lib/.build-id
        /var/log/zabbix
        /var/run/zabbix
        Thank you for the response.
        Here is what I have installed:
        rpm -qa | grep zabbix
        zabbix6.0-agent-6.0.29-1.el8.x86_64
        zabbix6.0-6.0.29-1.el8.x86_64
        zabbix6.0-selinux-6.0.29-1.el8.noarch
        zabbix-release-6.0-4.el8.noarch
        Kind Regards,
        Antonio
        • tim.mooney
          • Dec 2012
          • 1432
          If you point a web browser at the official Zabbix repo for RHEL 8, here:
          you can browse the package list.
          Your package is named "zabbix6.0-agent", but I don't see any agent packages in the repo that have "zabbix6.0" at the start of the name. It makes me wonder if maybe the packages are coming from somewhere else.
          What does the command
          sudo yum info zabbix6.0-agent
          output?
          • Rohaldos
            • May 2024
            output?
            Thank you for the response here is the output:
            dnf info zabbix6.0-agent
            Last metadata expiration check: 1:10:11 ago on Tue 21 May 2024 16:52:10 BST.
            Installed Packages
            Version : 6.0.29
            Release : 1.el8
            Architecture : x86_64
            Source : zabbix6.0-6.0.29-1.el8.src.rpm
            Repository : @System
            From repo : epel
            Summary : Zabbix agent
            URL : https://www.zabbix.com
            License : GPLv2+
            Description : Zabbix agent, to be installed on monitored systems
            Kind Regards,
            Antonio
            • tim.mooney
              • Dec 2012
              • 1432
              From repo : epel
              As you can see, the 'zabbix6.0-agent' came from the EPEL repo, not the official Zabbix repo.
              You may want to post on EPEL-specific forums to ask if there's an issue with the config file or the config directory for that package.
              If you want to prefer the official Zabbix packages, rather than these alternate packages from EPEL, you probably need to look into setting repository priorities: https://access.redhat.com/solutions/45244
              • Rohaldos
                • May 2024
                Hello Tim,
                Kind Regards,
