Problems creating Item prototype from Discovery rule
  • makkbe
    • May 2024
    Greetings! I've been trying to get this working for a couple of days now, but just can't seem to wrap my head around the process of correctly setting up Discovery rules and Item prototypes in Zabbix 6.0
    Long story short, I have a device that has an API that allows me to retrieve devices that are connected to it. The JSON output looks like this:
    "dev": {
    "receivers": {
    "8c:6d:c4:01:0c:40": {
    "alerts": {
    "testBuild": {
    "brief": "TEST BUILD",
    "count": 1,
    "desc": "Running firmware for test only: do not use in production",
    "severity": 4,
    "since": 69316
    "alertsCount": 1,
    "alertsSeverity": 4,
    "camera": {
    "disabledStream": 0,
    "enabled": true
    "counters": {
    "apRetries": 0,
    "apTimeouts": 0,
    "ethernetErrors": 0,
    "frameErrors": 0,
    "macErrors": 0,
    "reboots": 1252
    "distroBoxMac": "8c:6d:c4:00:a2:7f",
    "distroBoxPort": 1,
    "fans": {
    "Fan1": 0,
    "Fan2": 0
    "groupId": -1,
    "identifyEnabled": false,
    "info": {
    "backupConnected": false,
    "backupMac": "",
    "backupProcessor": "",
    "name": "EC1.5",
    "pixelsH": 180,
    "pixelsW": 320,
    "serial": "4",
    "version": {
    "firmware": "p23.07.14.21625 DEBUG"
    "ldms": {
    "1": {
    "info": {
    "serial": "SP154S017700"
    "2": {
    "info": {
    "serial": "SP154S017697"
    "3": {
    "info": {
    "serial": "SP154S017694"
    "4": {
    "info": {
    "serial": "SP154S017690*"
    "5": {
    "info": {
    "serial": "SP154S017699"
    "6": {
    "info": {
    "serial": "SP154S017696"
    "7": {
    "info": {
    "serial": "SP154S017693"
    "8": {
    "info": {
    "serial": "SP154S017689*"
    "9": {
    "info": {
    "serial": "SP154S017698"
    "10": {
    "info": {
    "serial": "SP154S017695"
    "11": {
    "info": {
    "serial": "SP154S017692"
    "12": {
    "info": {
    "serial": "SP154S017691*"
    "notes": {
    "color": 4294967295,
    "modified": -1,
    "text": ""
    "rotation": 0,
    "string": 0,
    "switchId": "",
    "switchPort": -1,
    "temps": {
    "CPU": 51.28,
    "Hub": 33.82,
    "PHY_B": 35,
    "PHY_L": 31,
    "PHY_R": 43,
    "PHY_T": 37
    "x": 0,
    "y": 0
    While this example only contains one device, a typical response could contain hundreds of devices, uniquely identified by their MAC addresses.
    I've created my Discovery rule as such:
    • Name: Discover Receivers
    • Type: HTTP Agent
    • Key: dev.receivers.discovery
    • URL: http://{HOST.IP}/api/v1/public?dev.receivers
    • Request method: GET
    • Preprocessing:
      • JSONPath: $.dev.receivers.*
    • LLD Macro:
      • Macro: {#MAC}
    And I've created an Item prototype as such:
    • Name: Receiver name for {#MAC}
    • Type: HTTP Agent
    • Key: dev.receiver.name[{#MAC}]
    • Preprocessing:
      • JSONPath: $.dev.receivers["{#MAC}"].info.name
    When I run the individual steps, everything appears to be working. However, upon executing the Discovery rule I'm getting error messages such as "Cannot create item: item with the same key "dev.receiver.name[{#MAC}]" already exists."
    I've tried various combination of HTTP Agents, Dependent items, etc. with no real luck. Would really appreciate some help before I give up on this project completely.
    Thanks!
