Value "4,38" of type "string" is not suitable for value type "Numeric (float)"
  • Eliafont
    • May 2024
    I'm monitoring an Oracle Database by applying the Template Oracle by ODBC.
    Searching on the forum the problem seems to be on the NLS_NUMERIC_CHARACTERS parameter conifiguration:
    select value
    from nls_session_parameters
    where parameter = 'NLS_NUMERIC_CHARACTERS';
    VALUE
    Unfortunatelly I'm not able to change permanently the parameter.
    I also see that a possible way to adjust this problem is by using a preprocessing and replace "." with "," and viceversa.
    However i'm looking for a more robust and modular solution.
    I tried to modify just the current session by adding this command inside the SQL query template
     ALTER SESSION SET NLS_NUMERIC_CHARACTERS = '.,';
    but i get the following error message:
    Cannot execute ODBC query: [SQL_ERROR]:[HY000][922][[Oracle][ODBC][Ora]ORA-00922: opzione mancante o non valida]
    Is there a way in zabbix I can modify this parameter without changing it permanently?
    Thanks for help.
    Regards.
  • Answer selected by Eliafont at 27-05-2024, 12:06.
    Eliafont
    • May 2024
    I solved the issue by creating the following trigger:
    HTML Code:
    CREATE OR REPLACE TRIGGER set_nls_on_logon
    AFTER LOGON ON DATABASE WHEN (user='C##ZABBIX')
    BEGIN
     EXECUTE IMMEDIATE 'ALTER SESSION SET NLS_NUMERIC_CHARACTERS = ''.,''';
    END; /
    • Eliafont
      • May 2024
      HTML Code:
      BEGIN
      END; /
