Cause and symptoms events zabbix - Zabbix 6.4
  • Ldzzzz
    • Feb 2024
    • 16
    Hello everyone,
    On Zabbix 6.4, are the symptom and cause problems only set manually? Or is there a way to automate all this so that as soon as a problem occurs, it displays the symptom problems to which the cause problem would be linked.
    This would allow me to have parent-child relationships with my hosts.
    The ultimate goal is to have the parent problem and, if desired, to scroll through the child problems in the same way as for the symptoms.
    If this isn't possible, I don't see the point of this feature if we have to do everything by hand every time.
    Thank you for your time and your answers.​
