Apache Tomcat by JMX template problem
  • sandorv
    • May 2024
    Hi there,
    I have installed the Agent 2 (version 6.4.14) and the Agent 2 plugins. The Zabbix server is running from a VM on my Windows machine.
    I have a Tomcat based Java application in Windows. The Tomcat/Java application is installed as a service, but the Zabbix server doesn't see it. As I red, the Apache Tomcat by JMX template might needed to be able to monitor it, but when I try to install the template, I'm getting the following error:
    Cannot inherit item with key "jmx["Catalina:type=Server",serverInfo]" of template "Apache Tomcat by JMX" to host "Windows ownmachine", because a host interface of type "JMX" is required.
    Do you have any idea what do I have to do to make this work?
