Problems while integrating Meraki Dashboard into Zabbix
  • ArneStrauss
    • May 2024
    Hey,
    I've got some issues on Integrating the Meraki Dashboard into the Zabbix.
    I get allways following error when I Test my template: "Failed to parse response received from Meraki API. Check debug log for more information." The specific Error is the following "SyntaxError: invalid json (at offset 1)"
    var params = JSON.parse(value);
    var request = new HttpRequest();
    request.addHeader('X-Cisco-Meraki-API-Key:' + params.token);
    request.addHeader('User-Agent: ZabbixServer/1.1 Zabbix');
    var response,
    error_msg = '',
    organizations = [],
    devices = [],
    network_id = "",
    network_name = "",
    networks = [],
    organization = [];
    function getHttpData(url) {
    response = request.get(url);
    Zabbix.log(4, '[ Meraki API ] [ ' + url + ' ] Received response with status code ' + request.getStatus() + ': ' + response);
    if (response !== null) {
    if (typeof (response) !== 'object'){
    try {
    response = JSON.parse(response);
    catch (error) {
    throw 'Failed to parse response received from Meraki API. Check debug log for more information.';
    if (request.getStatus() !== 200) {
    if (response.errors) {
    throw response.errors.join(', ');
    } else {
    throw 'Failed to receive data: invalid response status code.';
    if (typeof (response) !== 'object' || response === null) {
    throw 'Cannot process response data: received data is not an object.';
    return response;
    try {
    if (params.token === '{' + '$MERAKI.TOKEN}') {
    throw 'Please change {' + '$MERAKI.TOKEN} macro to the proper value.';
    if (params.url.indexOf('http://') === -1 && params.url.indexOf('https://') === -1) {
    params.url = 'https://' + params.url;
    if (!params.url.endsWith('/')) {
    params.url += '/';
    if (typeof params.httpproxy !== 'undefined' && params.httpproxy !== '') {
    request.setProxy(params.httpproxy);
    organizations = getHttpData(params.url + 'organizations');
    if (Array.isArray(organizations) && organizations.length > 0) {
    for (i in organizations) {
    if ('id' in organizations[i]) {
    organization_networks = getHttpData(params.url + 'organizations/' + encodeURIComponent(organizations[i].id) + '/networks');
    if (Array.isArray(organization_networks) && organization_networks.length > 0) {
    for (y in organization_networks) {
    if ('id' in organization_networks[y]) {
    if ((organization_networks[y].id === params.networkid) || organization_networks[y].name === params.networkname) {
    network_id = organization_networks[y].id;
    network_name = organization_networks[y].name
    organization_devices = getHttpData(params.url + 'organizations/' + encodeURIComponent(organizations[i].id) + '/devices/statuses');
    if (Array.isArray(organization_devices) && organization_devices.length > 0) {
    for (j in organization_devices) {
    if (organization_devices[j].networkId === network_id) {
    organization_devices[j].organizationId = organizations[i].id;
    if (!organization_devices[j].name) {
    organization_devices[j].name = organization_devices[j].serial;
    if (!organization_devices[j].networkname) {
    organization_devices[j].networkName = network_name;
    organization[0] = organizations[i];
    networks[0] = getHttpData(params.url + 'organizations/' + encodeURIComponent(organizations[i].id) + '/networks/' + network_id);
    devices.push(organization_devices[j]);
    } catch (error) {
    error_msg = error;
    return JSON.stringify({
    'organizations': organization,
    'networks': networks,
    'devices': devices,
    'error': error_msg.toString()
    It would be great if someone could help me while finding a solution.
    Is there a possibility to Debug these Item directly in Zabbix?
    Thank you very much
    Arne
