New to Zabbix .. Discovery seems to not work when adding VMware template
  • dubfunkle
    • May 2024
    • 11
    Hi guys,
    I just set up Zabbix 6.4.15 on Ubuntu 24.04 and followed the below guide to add my VMware environment. I did this a few times but discovery doesn't seem to be triggering. I also cannot find the execute now button so I assume this is being done automatically. Any help would be much appreciated! Thanks
  • Answer selected by dubfunkle at 30-05-2024, 09:36.
    dubfunkle
    • May 2024
    • 11
    Thanks and apologies for the late reply. I had another warning saying that Zabbix server was not running even though it was. I checked about this and at first I thought it was a false positive but turned out it was not. I just re-installed everything to be honest and now everything seems running fine. Cheers!
      Too little info here...
      Did you start vmware collector(s)? Created a host with all the needed macros etc?
      Do you see anything in Zabbix server logs about vmware... ? Theres also some extended logging options mentioned here https://www.zabbix.com/documentation...-use-templates
      • dubfunkle
        • May 2024
        • 11
