Docker plugin with active agent
  • Isi
    • May 2024
    The "Docker by Zabbix agent 2" doesn(t fetch data with active agent on monitored host.
    I found an homemade template : https://github.com/Futur-Tech/futur-tech-zabbix-docker for active agent.
    What is your opinion on this homemade template?
    Could Zabbix develop an official "Docker by Zabbix agent active"?
    Thank you for your feedback
    • 4990
    I don't see any reason why you should not be able to use official docker template with active agent.. Just need to change those couple of items from passive to active...
    https://git.zabbix.com/projects/ZBX/...at=release/6.4
