Two zabbix instances, access control via LDAP
  • ipguy
    • Nov 2010
    • 12
    I have two zabbix instances that I need to setup LDAP authentication against my FreeIPA server
    All users exit via FreeIPA
    ZabbixA would need to authenticate userA via FreeIPA
    ZabbixB should not allow userA to authenticate via FreeIPA
    Is this use case achievable with Zabbix?
  • ipguy
    • Nov 2010
    • 12
    bump, anyone have any comments here?
      If those are different instances, then why not... If you mean 2 GUIs with same DB, then not.
      • GandalfG
        GandalfG commented
        I aggree, but if the 2 instances are in a cluster, then I cannot see how this should be done...
