How to combine Items
  • on_air_
    • May 2024
    Dear Community,
    i'm new to Zabbix just making my first steps.
    I set up an environment monitoring our whole environment from hypervisors to network switches. Works very well so far.
    We created a few dashboards to indicate the workload of different host groups using the "Top Hosts" widget.
    Now we wondered if it is possible to combine two or more items in one Dataset (e.g. Windows Memory utilization and Linux Memory utilization) so we can monitor the same type of value from different platforms in the same widget
    Many thanks in advance!
  • tcweb
    • Jun 2024
    • 57
    I have the same question. I have found that I can create a CPU widget, and if I use the new "override host" feature in zabbix7, it WILL switch between windows and linux hosts.
    However memory does not seem to behave the same way. At least I have not figured it out yet...
