Can't get ldap(s) to work at Zabbix 7.0 rc2
  • zabbixuser39393
    • Jan 2021
    • 38
    Environment:
    Red Hat 9.4
    Zabbix 7.0 rc 2
    Nginx 1.20.1
    PHP 8.0.30
    Nginx configuration = zabbix server configuration
    I have tested that ldap and ldap connector account works at server console.
    Configured and tested ldaps settings with name, ip, ldaps: etc, Bind with OU and "e-mail format"(I think that I have tested all variations )
    I have tried look audit.log and run
    grep [different_values_from_audit.log] /var/log/audit/audit.log | audit2allow -M zabbix_server_custom
    semodule -i zabbix_server_custom.pp
    But no success.
    Login failed
    Cannot bind to LDAP server
    Now I need advices to what I should to check next. Directory permissions? Directory owners and groups. Nginx / Zabbix run as settings etc. or what.
    Thanks for Your time using for reading this and maybe answering...
  • zabbixuser39393
    • Jan 2021
    • 38
    OK, I did install rc 3 update and this did messed whole system. Now web-page gives forbidden and nginx - zabbix and php-fm runs differen users (root - zabbix - apache). So I think that I install this as new and again...
    • zabbixuser39393
      • Jan 2021
      • 38
      Fresh install to 7.0 rc3, but ldap problems continues...
      Any meaning about this?
      type=SERVICE_STOP msg=audit(1717057231.879:36293): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=zabbix-web-service comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'UID="root" AUID="unset"
      • zabbixuser39393
        • Jan 2021
        • 38
        Updates Now every second to every fouth test will succeeded at Users / Authentications /ldaps configurations test. So it is unstable and does not work every time.
        • zabbixuser39393
          • Jan 2021
          • 38
          This is weird... Now it does not work at all again
