Monitoring oracle with zabbix agent2
  • Mugugnu
    • Dec 2020
    • 10
    Hello community!
    I am trying to figure out why zabbix agent 2 (6.4) cannot retrieve metrics for any permanent tablespace except temp (which is temporary).
    I am getting this error "Cannot fetch data: Next: ORA-01013: user requested cancel of current operation." and already tried to raise agent timeout to its 30 sec max with no success.
    is there a way to know what queries are actually being performed by Oracle by Zabbix agent 2 templates ? I would like to manually execute them with user zabbix_mon and see wether they work or not. In alternative how can i debug this problem ?
    Any support appreciated !!
    Thanks and regards!
  • claudio.gajardo
    • Jul 2024
    Mismo Problema por acá después de actualizar a zabbix 7, tuve que pasar de Oracle by ODBC a este template y tengo exactamente el mismo problema... la base de datos que estoy monitoreando es versión 18.14
    • claudio.gajardo
      • Jul 2024
      ok, tengo la solución:
      En el servidor que se esta monitoreando se debe cambiar un parámetro del agente.
      En el directorio: /etc/zabbix/zabbix_agent2.d/plugins.d
      se debe editar el archivo oracle.conf:
      y al inicio, en la seccion de CallTimeout se debe configurar Plugins.Oracle.CallTimeout=30
      ### Option: Plugins.Oracle.CallTimeout
      # The maximum time in seconds for waiting when a request has to be done.
      # Mandatory: no
      # Range: 1-30
      # Default:
      # Plugins.Oracle.CallTimeout=<Global timeout>
      luego se debe reiniciar el agente:
      systemctl stop zabbix-agent2.service; systemctl start zabbix-agent2.service; tail -f /var/log/zabbix/zabbix_agent2.log
