Determining Ideal Cache Size for Zabbix Server Monitoring 50 Servers
  • Biltu
    • May 2024
    Hello Zabbix Community,
    I'm managing a Zabbix installation that monitors 50 servers within our infrastructure. I'm seeking advice on determining the ideal cache size for our Zabbix server to optimize performance and resource utilization.
  • Markku
    • Sep 2018
    • 1784
    It is mostly quite easy actually: ensure that you are monitoring the Zabbix server with the Zabbix server template, and you will get triggers that alert you about resources starving. Just start with the default valuesand adjust later if specifically needed.
    Markku
