Zabbix Inventory Export
  • Daniel4711
    • Jul 2014
    • 127
    I am currently introducing Zabbix at my new employer and am considering whether to use Inventory here.
    Unfortunately, the default inventory fields do not match our requirements.
    So I thought about changing them via the file /usr/share/zabbix/ui/include/hosts.inc.php.
    At least the pure display in the frontend.
    As changes are coming with Zabbix 7.2, I am considering whether I should export the computer name, inventory field and value to be on the safe side.
    Can anyone give me any advice on this?
    Due to a lack of Postgresql knowledge, I can't even find the right table for the values.
    Many thanks in advance
    Daniel
    host inventory is in the table called... surprise, surprise "host_inventory" ..
    7.2 is still far away, 7.0 just came out.. You have plenty of time to think, what you are going to do with your custom field names...
    • Daniel4711
      • Jul 2014
      • 127
      Thanks for your Answer!
      I must have been blind!
      That's really unpleasant for me now​​
