Agent become unavailable after upgrade to Zabbix 7.0
  • sokeada
    • Jun 2024
    • 25
    Dear All,
    I've successes in place upgrade my Zabbix 6.0.30 LTS to 7.0.0 LTS but after few hours, zabbix agent become unavailable, when check the log, looks like it cannot access the the server IP. Anyone have any idea, please.
    2024/06/05 11:47:32.565705 Zabbix Agent2 hostname: [Zabbix server]
    2024/06/05 11:47:33.567090 [101] cannot connect to [127.0.0.1:10051]: dial tcp :0->127.0.0.1:10051: connect: connection refused
    2024/06/05 11:47:33.567147 [101] active check configuration update from host [Zabbix server] started to fail
    2024/06/05 11:47:33.567552 [101] cannot connect to [127.0.0.1:10051]: dial tcp :0->127.0.0.1:10051: connect: connection refused
    2024/06/05 11:47:33.567586 [101] sending of heartbeat message for [Zabbix server] started to fail
    2024/06/05 11:48:06.590937 [101] cannot receive data from [127.0.0.1:10051]: Cannot read message: 'read tcp 127.0.0.1:42327->127.0.0.1:10051: i/o timeout'
    2024/06/05 11:48:06.621729 [101] active check configuration update from host [Zabbix server] started to fail
    2024/06/05 11:48:12.569712 [101] active check configuration update from [127.0.0.1:10051] is working again
    2024/06/05 11:48:34.567352 [101] sending of heartbeat message to [127.0.0.1:10051] is working again
    2024/06/06 08:48:14.644420 Zabbix Agent 2 stopped. (7.0.0)
    Thanks,
    Sokeada
  • sles
    • Oct 2005
    • 80
    Why server has address 127.0.0.1 ?
    • sokeada
      • Jun 2024
      • 25
      because it a stand alone Zabbix server, agent is came as default installation.
      • Markku
        • Sep 2018
        • 1784
        What did your Zabbix server log say at the same time?
        Markku
        • sokeada
          • Jun 2024
          • 25
          the above message is from the agent log, I compared with 6.0 agent log both are identical but I have not idea why the service stop itself and can't be started.
          • mskenderian
            • Jan 2021
            • 9
            I have the same issue, i jsut upgrade from v6 to v7 and my zabbix server agent is not connecting.
            Get value from agent failed: Cannot establish TCP connection to [[127.0.0.1]:10050]: [111] Connection refused
            • sokeada
              sokeada commented
              I've found a solution, I just stop or remove agent2 then install agent1. After making sure the agent 1 is running then stop and disable agent 1, then install agent2, check the status, it should be running. That's what I have done and been using a week plus till now.
          • Markku
            • Sep 2018
            • 1784
            Is your agent running? What does its log say?
            Markku
            • mskenderian
              • Jan 2021
              • 9
              logs didnt have any issues.
              i think something was wrong with my config file, i removed everything and reinstall it, same issue, then I realized that its the plugins, postgres and mongo, remove those *.conf and it works fine now
              i stop the service and manually ran
              zabbix_agent2 -c /etc/zabbix/zabbix_agent2.conf
              thats how i found about the plugin issues
